Just did my 15K service and the engine is now exhibiting a high-frequency
buzz that I can feel in the bars, pegs and tank. Engine starts and idles fine.
Power and gas mileage same as before.
Only diff is the buzz, which is very annoying when cruising on the backroads or freeway.
I had the front cams out for a shim swap.
Could the cam chain be off by 1-tooth?
I tend to think this would create more symptoms than just vibes, but am not sure.
Could bad carb sync cause vibration at speed?
I'm hoping that's the cause, as it would be much less work to correct than a cam timing issue.
I also changed the coolant, air filter & spark plugs, but I don't see how those
could cause engine vibration. The AF is stock and the plugs are the same
NGK iridiums I had in before.
Any info appreciated.
Thanks.
Thanks.
