What's good yall?
Every once in awhile we see a new owner experiencing issues getting used to the engine braking on the SV, as it is much stronger then on some other bikes.
After swapping from the stock N bars to the SVRP clip ons, my idle dropped to about 1K, previously it was set around 1300.
I had also previously adjusted TPS to 1350 or so.
I rode the bike a couple times with the idle set at 1k and I noticed a high amount of engine braking upon downshifting.
Raised my idle back up to 1300 and guess what? Engine braking is much more controllable and feels as it should.
So TLDR, if your having trouble getting used to the engine braking on the SV, check your idle setting and your TPS adjustment, because when you get everything set properly, the engine braking becomes smooth and predictable, much less throttle needed on downshifts to rev match.
