1 - 1 of 1 Posts
Suzuki SV650 Riders Forum
mxwllneidigh
I need help!
Jump to LatestUnfollow
1 - 1 of 1 Posts
[IMG alt="mxwllneidigh"]https://www.svrider.com/d2/avatars/m/194/194400.jpg?1598741148[/IMG]
mxwllneidigh
Joined 1 h ago
Discussion Starter • #1 1 h ago
Okay, so I recently purchased a 2001 sv650 and everything was fine. Old battery but the thing ran and did everything it was supposed to. Fast forward about 3 weeks, battery took a dump, We jumped it at a gas station, the low beams were off, the tach wasn't reading at all, and the speedo was only coming on if I revved it up as if it was the tach. Tried to make it back but the battery was toast and wouldn't hold a charge for anything. So, I replaced the battery, it wouldn't turn over, checked everything and found the coils weren't sending spark to the spark plugs, got a new cdi and r/r and the thing turns over, runs fine, just still have no tach, I'm assuming no speedo, but I haven't taken it out, and no low beam. All other lights work, the neutral light works on the dashboard and the others too. I checked the fuse box and they're all not corroded and are not popped. Is there another thing that could be wrong with those? Or am I going to have to start looking for grounded wires somewhere?
Any help would be appreciated,
Thank you.
1 - 1 of 1 Posts
