1 - 3 of 3 Posts
I have noticed my bikes lights are flickering, but sort of fade to bright. It is happening on the headlights, cluster indicator lights and the rear brake light.
Does anyone know what the issue could be. How should I trouble shoot this?
Thanks.
I'm not sure what you mean by "fade to bright."
Do the lights fade? or do they get darker?
In any case, first things is always to check that battery, and battery terminals.
Check to make sure your battery terminals are screwed in well and not loose.
If they're good to go take a look at these links and turn the electrical system tests there in. It could be a charging system problem: RR mod how-to (svrider.com) and Charging system diagnostic r/r upgrade (eviltwinsbk.com).
If the battery terminals are secure and no problem with the rest of the charging system then it could be a short but take out the easier stuff first.
1 - 3 of 3 Posts
