"Tudi!"Some crimp on connectors and a battery? Play around with the gauges connector with it.
"Hit em again Endo!"
Off the bike - just want to check the mileage.Is the gauge cluster off the bike? I'm not sure what you're looking to do. Just turn the lights on? Check each individual function?
nopeIsn't the mileage in the ecu?
Well definitely contact him, he's the joker that figured out how to clock them iirc. Apparently he found there's a limit as to how fast you can make the odo tick over hahahahaahh.Off the bike - just want to check the mileage.
There are 2 ground wires on the gauge cluster. Both are black with a white stripe. All the others power something. I'm not sure of the voltage ratings on every instrument on the panel, but odds are it would be 12V. What I would try to do is to use a 9 volt battery. Just hook up the black/white to the large side, and run the other wires to the small. If that doesn't provide enough juice you could always try a wall wart.Off the bike - just want to check the mileage.
Risky proposition, that.EDIT:Or you could listen to TCL.
R/W and O/G both go right to the fuse block. Could be R/W but I don't see how O/G is temp. Red would make sense...Ground is B/W however the power is the red wire. O/G is for the coolant temp.
Probably going to need 12V.
