Last time it was seen on these forums, the front fender was the only piece of bodywork. Here it is with a dummy tank and some really nasty side panels. Just installed the tail cowling this afternoon and took a few pics. Whaddya think?
The heaviest bit of the fairing was the nose/cowling/windscreen, and that got trimmed off. The side panels and tail weigh approximately nothing, ditto the tank, which is just the outer skin. Maybe added 5 lb. total, less than 1% of the bike with rider. Oh yeah, the battery charger had to be removed to fit the tail, so that deducts ~18 lb.! So did the big instrument panel, another coupla pounds gone (I just don't know how fast I'm going or how much juice I gots left anymore!).Why the extra weight of a Fairing, on something that every ounce steals power/milage???
Getting mixed messages here, the rolleyes would seem to indicate that you couldn't care less!How does it run?????
Might go back to nekkid soon. It's convenient to have the charger on board, as it also keeps up with battery state of charge in addition to allowing recharging away from the house.I saw your first thread, and I'll say it again, that is awesome! It's because of creative folks like you that we get new and better technology.
To me it looks better naked so you can see the guts. Plus, it's home built electric; it's got so much personality it doesn't have to look pretty, lol! ;D
It was surprisingly easy. The alternator/generator went bye-bye, did some machining on the outside of the left-side engine casing to allow the motor to bolt up (from the inside) to it with a spacer. The SV's crank was sawed off, only the right side remaining to ride in the right-side bearing and to drive the clutch/trans. An adapter coupling was made to mate the electric motor's output shaft to the stub end of the SV's crank.Do you have any close up pictures of how you coupled the motor?
Thank you very much!Great job man!
Mainly what I need is lithium batteries. That would knock off about 100 lb! Bike weighs ~480 lb. at the moment.
I would think the main problem with that is that it is "low power" not to mention the radiation dangers. :nana:That is an absolutely psychotic mod! Talk about "out of the box;" that's out of the realm of most SVers' imagination.
Very, very cool. Have you thought about swapping out the batteries for a low-power nuclear generator, like a satellite might use? Very long rides would then be possible.
Thousands of dollars. But they're cool.What price difference would it be to use LiON batteries vs. the ones currently on it.
Have you seen Hasselblad's new 60MP camera? lolA+ on your ingenuity and ability to make it happen!
New battery technology and better availability will make this type of project a lot easier and practical in the near future.
The capabilities of electric motors are amazing. We have electric RC trucks that out perform the nitro versions significantly. A small 4-wheel drive truck with a brushless motor and 2) 7.4V NiMH batteries in series will run an honest 50 mph. Use LiPo batteries and it adds another 10-15mph. The brushless motor has just a couple of parts to it and is more efficient than a regular brushed motor. Performance of electric vehicles will continue to improve.
When digital photography first came out I was a professional photographer with top-notch film equipment. Based on what I saw I thought that there was no way digital could out-perform film - boy was I wrong - it surpassed film and isn't stopping any time soon.
I'm not betting against electric power systems doing the same.
Jay
