1 - 10 of 10 Posts
Well had the bike tossed on the Dyno today at Mid-ohio. Bike has desnorkel,scorpion h/m slip, tank riser,PCIII USB, and +3 rear sprocket.
It was 93 degrees out and the dyno sheet says 29% hum. but i highly doubt it was even close to being that low. I'd say more like 70%. but put down 71.95hp with the stock filter too.
The third pull was a run through the gears, hence the valleys. idk why my scanner didnt show it in color......And i wish i got the torque numbers, oh well.
How did you get your dyno graph on here? mine is printed out on a sheet of paper. I had mine done with my mods listed below and had the pcIII dyno tuned and made 75.1 hp!
reading comprehension 101
See where it says"idk why my scanner didnt show it in color". that means he used a scanner. see scan = scanner it's a device you can hook up to your computer and.........well............ scan thing like pictures and documents.
Your Welcome
haha. Those are good numbers! I think mine is do to the stock filter and i've only got a pre load map for a slip on and aftermarket filter. I'll be goin full exhaust with a possible pod setup later. i think i'm runnin a lil rich now.
man dhuze...u sure are a smartass! I noticed the scanner comment after i posted. sorry i wasnt the eagle eye that you are.
yah i would say if you are gonna do a full system and everything else you should get dyno tuned and you will definately get the results you want out of your mods. Before i dyno tuned i used one of their premade maps also and made just over 72 hp. They told me removing the snorkle didnt give them any better results which i think is crap
owndjoo - Get to Bucyrus and have JD Hord run and set up your bike. It costs $60 for an hours worth of tuning. You'll never get more power out of your bike any where else. He builds race motors for SV's. He is a twin specialist too (Ducati and Hawk's).
It'll be the best money you ever spent.
phelix said:
man dhuze...u sure are a smartass! .................
Maybe just a little :wink:
thanks wacky, i'll have to remember that. planning on gettin the full system and everything together this winter and start runnin some VPfuel for the race season, so i'll need to get 2 maps made. pump gas and race gas.
Do you know?
Do you know that the gear ratio has no effect on horsepower? Just mentioned that since you specified +3 on the rear sprocket.
1 - 10 of 10 Posts
