So I bought an HID Bi-Xenon Kit for my 2006 SV650s. I have the Aztec8 dual H4 headlight kit that has two H4 60/55 watt bulbs.
I bought an HID kit with the following specifications on each of the ballast (there are two ballasts for this kit):
Voltage In: 8-22 volts
Votage normal: 13.2V
I norm: 3.2A
I max: 20A
Power Output: 35W
V star: 23kv max
I wired it all up and got both of the bulbs to turn on with the both the high and low beam. But then sometimes when I would turn it on only one would come on, none of them would come on and sometimes both would come on. I checked all of the connections with a multimeter and there was current through the system.
I contacted the person I bought it from and they said that each ballast needs 8 Volts and 20A to fire up the bulbs.
They suggested some type of relay to boost the power from the battery.
Can anyone help me out. Do I need a relay to boost the power from the battery or do I need a more powerful battery.
Any help would be great.
Thanks.
I norm: 3.2A
I max: 20A
Power Output: 35W
V star: 23kv max
Thanks.
