Can someone explain the differences? I hear about it all the time and don't really understand the concept. What are the pro's and con's of each?
I believe Aprilia has dry sumps too.Ivan said:I think just about all bike engines except for Ducatis are wet sump. And many wet sump engines are just fine because the oil pickups are always covered by oil (unless your bike is upside-down).
Actually they are not pumps.Ivan said:Dry sump and wet sump are very similar.
Wet sump pumps the oil from the bottom of the engine directly to the top of the engine.
Dry sump pumps the oil from the bottom of the engine to a reservoir. Reservoir pumps to the top of the engine.
Addressed but, not completely corrected.abass84 said:Do all Sv's suffer from oil starvation due to wheelies, or did Suzuki correct this in later models? Just curious because i own an 01
By removing the volume required to accomodate the wet sump, the rest of the engine (crank and above) can be lower in the chassis without affecting ground clearance. Moving the oil to a dry sump tank somewhere in line with the engine itself will not raise the CG (oil is has generally less mass than the same volume of alloy) and the center of mass would be lower (albeit setretched out along the longditudinal axis of the bike.). The way you explained it sounded like you swapped dry and wet.
