'03
I just got done draining my tank and putting new gas in; I think I got some bad gas. After finishing the work and putting up my tools, I decided to put a little fuel injector cleaner in the tank.
When I unscrewed the top, the little stryofoam/plastic thing that is pressed into the top of caps popped out (about the size of a dime). I watched in horror as it fell directly towards my gas tank and dissappeared inside.
I don't think that draining the tank again would do any good. The way the inlet to the tank is shaped i could get almost all of the gas out, but the cap would stay inside.
I tried topping off the tank and hoped that it would float to the top, but it didn't work.
Two questions:
1.) Do you think that the cap will cause problems if it is just floating around in the tank? If it dissolves in the tank will it clog up my fuel injectors?
2.) Any other ideas how to get it out? If I remove the fuel pump will I have complete access to the inside of the tank?
Two questions:
