1 - 13 of 13 Posts
I'm thinking about making my own SS lines, but quick question.
There is a double banjo bolt on that little brake manifold that splits the line to the two front caliper. Can I reuse that bolt for the master cylinder to connect two lines?
I found this photo on the repair manual. That's the bolt I'm talking about. What's the difference between a splitter and a double banjo?
I'm thinking about making my own SS lines...
Are you sure you want to do this?
If you dont' have experience and the proper special tools, there are many situations where a failed front brake line could kill you. :(
Im pretty sure that is a double banjo.. i just took my frontend apart yesterday and remember looking at and asking myself the same question... 'can i use this at the master??'
it's easy, 1 line=regular banjo bolt..2 lines=double banjo bolt..
As long as it's threaded the same I don't see it being a problem.
Like TeeRiver brought up, just make sure you know what you're doing or have someone check it over. You don't want to find out the hard way that you lost your brakes...
I crimp stainless lines all the time for diesel injection and direct injection systems. (5k psi of pressure) so no worries.
Do you know if the threads are the same? I don't want to take it apart, only to have different threads and have couple days of downtime while I wait for another one.
**Mini-thread jack alert** I recently purchased galfer ss lines and the mc banjo bolt that came with the lines does NOT fit my 00-03 gsxr 750 master cylinder, does anyone know if the stock double banjo is still safe to use instead of the new galfer double banjo?
Does anyone know the part number or the thread pitch for the double banjo bolt (DBB) that Galfer provides for their SV lines or another company that makes the hardware? I don't think the splitter bolt will work because I tried it out with another splitter bolt off another bike and realized the two ports are spread further apart than the DBB. I guess you might be able to fill the gap with some copper washers or something, but it's sketchy, plus mine wasn't the right threading anyway.
it isn't the fine one. they should offer two, fine and (coarse I believe). It isnt the fine. I used the one from a ducati since i had a pressure sensor
I found out it's the M10x1mm for the master and the calipers are a M10x1.25mm. FYI.
1 - 13 of 13 Posts
