1 - 13 of 13 Posts
Installing svrp rear set riser plates....do I need the kick plate support bracket on the brake side?
Sent from my RAZR MAXX using Motorcycle.com App
Didn't think so :) thanks
I am a little disappointed that I can't use a lot of the settings on the riser plate due to the spring tab for the brake light switch :/
very big dumb
isn't it actually the spring tab for the brake pedal that's in your way iirc?
I'm pretty sure that's the rear blinker light fluid actuator I could be wrong though.
remove the spring and conventrional switch. install the pressure banjo switch like other people have said. makes it worlds easier.
MOTORADOR
1 - 13 of 13 Posts
