So you got a fender eliminator and don't feel like paying $20 for a plate light, you don't have to. Ride on down to radioshack and get 4, 3.3V white LED's.
you should also have a
hot glue gun
soldering iron and solder
some wire
wire cutters
Take this piece off the bike (mine had a hole in it for some reason? But im going to get the bike painted sometime so i filled it in.)
Drill four holes, you should angle them toward the license plate because LED's have a low viewing angle.
You have to solder the LED's in series. (so the 4 3.3V LEDs will act as a 13.2V bulb, and not burn out) LED's do have polarity so you have to pay special attention to which side is + or -. If you look closely at an led one side is flat.( the flat side if + .?)
Use hot glue to keep the LED in place and solder them together in series, NOT PARALLEL they will burn out instantly.
I sanded off the paint when i filled in the hole, this is how it looked. Covered the leads in hot glue to prevent it from shorting out in rain.
Connected it
and
if it doesn't turn on, make sure your polarity is correct.
hot glue gun
some wire
wire cutters
Connected it
and
