Ok...
Like many of you, I'm unwilling to pay the outrageous price that Suzuki wants for the Steering stem nut socket ($169 Cdn), so I decided to try and make my own.
I've seen some people use a grinder on a 1-1/4" deep socket, which was my original intention, however I couldn't find a deep socket for little $.
I then also saw Motophoria here on SVRIDER use some galvanized steel plumbing parts with some steel rod.
I managed to get my hands on a steering stem nut that I could use as a template...
So here's my take on the idea for less than $8US in parts...
I went into the plumbing section of my local hardware store, and grabbed:
- 1-1/4" threaded 4" galvanized steel pipe
- 1-1/4" to 1" galvanized steel reducer
- 1" galvanized steel threaded cap
Using a marker, I marked out the areas that had to be cut out using a locknut as a template. I also used a visual aid to show how much depth I needed to grind away.
I then grabbed some proper eyewear...
I placed the pipe in a vise, and using a grinder I ground away...
I used a file to clean up the edges and properly fit the nut
Once I knew I was as close as I'd get, I screwed the 3 pieces together using some steel epoxy. It's still drying, so I have yet to use it. I'm pretty sure it'll work just fine...
Oh yeah, the top cap can be used with an open end wrench, or a socket (I think 21mm or 22mm)
It's not as pretty as the Suzuki tool, but it will get the job done without mutilating the soft-as-butter aluminum locknut by using a hammer and a screwdriver.
