Difference in clutch release mechanisms from 99 to 02?
753 views 1 reply 2 participants last post by  ejl10
Well my SV started having a really quiet high pitched squeal at traffic lights and was a PITA to be in gear. So tonight I pull off the countershaft cover to investigate , I remove the clutch screw release assemble and the ball bearings just fall all over the place. Then I pulled out the clutch push rod from the tranny case and find it with a nice bow :(
The inner screw is thingy is still in good shape so I shouldn't need to replace it.
How much should I expect to get taken for at my local Suzuki stealership for the release assemble and the push rod? Has anyone else had this issue with their first Gen SV?
#2 ·
I don't know the part, but you can probably find it in the OEM part diagrams at BikeBandit.com or RonAyers.com. Their pricing is usually pretty close to a dealer's. You can also check to see if the 99 and 02 use the same part number.
