1 - 4 of 4 Posts
My K8 naked is gonna get a treat within the next 2 or 3 weeks - RT emus, Eibach springs, and fresh oil up front; and SOME sort of new aftermarket shock out back.
Here in Canada, options are kinda limited: pretty much only Elka or Penske at the 'high quality' end. Alternatives like Cogent do not have agencies up here, which makes rebuilds inconvenient. Both the Canadian and American Ohlins distributors have surprised me by saying they cannot supply a remote reservoir shock that'll fit my ABS-equipped bike, so that option is out.
I'm leaning towards the Penske Sport (damping-adjustable only; about C$800 up here). Penske gets very high praise on this site, and has lots of Cdn support, easy quick local rebuilds, etc. The price on the 2-way Elka is very tempting (about C$900), but I have heard a couple negative comments during my shopping (a. the shock is heavier than its competitors, and b. the local suspension specialist reckons they do some unspecified stuff internally that he didn't think was as 'top-end' as Penske or Ohlins). The 2-way Penske is about C$1100 locally, quite a bit more, but possible if I 'need' it.
My question is, do some of you have experience with BOTH "1-way" damping-adjustable-only shocks as well as 2-way and/or 3-way? Is the extra adjustability worth the extra expense, for an enthusiastic-but-non-racing rider? Does one notice 'fade' with the simpler emulsion-based 1-way units on hot days? on track days? after an hour or two (or 6?) of 'sporty' road riding? or never? I've read posts here saying good things about the Cogent shock, for instance (mostly just rebound adjustment), but never comparisons between the 'levels' of adjustability.
Btw, for context, I commute 2-3 days per week year round @ 30km/day, put on about 15,000 km/yr of 'spirited' road/highway riding/touring, and get out to 2-3 track days/yr. And I'm a late-middled-aged returnee rider with only 2 years "back in the saddle", so my experience base is low - but growing as fast as I can manage it!
Cheers,
Banned
I personally think it's worth it. The ability to tune rebound and compression independently can make the difference between having your damping set up to 'kinda how you want it' and 'close to ideal.' A shock with additional adjustment of high and low speed damping such as a 3-way offers is even better. The down sides are, obviously, cost and complexity of tuning. Though the 'complexity' can be a good or bad thing depending on what you want.
I like a lot of adjustability on suspension components, both on-road and off-road(track) applications. As far as the 'need' for adjustability, you could bolt a steel rod to the back of you bike and it's still be ridable.
I've played with most kinds of shocks except for 3-way adjustable shocks. Cost prohibitive as far as I'm concerned.
The "third way" on three way adjustable dampers is for high speed damping (when the damper shaft is moving "fast", usually over over 5 inches per second up of damper shaft velocity) and effects the way the shock responds over sharp-edged bumps like pot holes. The adjustability of this third aspect of the shock tends to be of a fairly small range and on some brands of shocks darn close to non existent. On top of the narrow range of adjustment, most riders have a really difficult time discerning what is going on in that range. The adjusters all have a certain amount of "cross-talk" so they effect each other to some degree.
I typically recomend the three-way adjustable shocks for people who LIKE to play around with their suspension. The two way adjusters are really all most of us need.
Even with the double adjustable shocks, there are a lot of differences in the design of the adjuster mechanisms and a different brand of shock will often have a far better level of control as well as improve the overall performance of a shock (most often by incorporating an auxiliary shim stack as part of the adjuster).
1 - 4 of 4 Posts
