1 - 7 of 7 Posts
Where can I get these? I'm pretty sure I have a leak on the left banjo bolt going into the oil cooler. Can I use the same copper crush washer I would use on my brake lines? If not can someone recommend a place to buy these? Its a very slow leak and tightening the bolt didnt seem to help..
is the washer on the correct side of the oil line?? like, did you have it apart recently and maybe put it on th ewrong side?? there is only one washer if i remember correctly. The banjo bolt should make it pretty obvious where the washer goes.
no this is all stock... aside from recently tightening the banjo bolt I have not had the oil cooler off. The leak seems to be coming from the bolt/hose connection, not sure how or why but it drips about 2-3 drops a day. the underside of my engine block is always oily and greasy...
1 - 7 of 7 Posts
