1 - 3 of 3 Posts
The hanes manual says when changing out the rear brake I need a "copper based geese" but all they have in the stores is for ceramic pads. Will this stuff work or keep searching??
Are you using the grease for the back plate of the pads to alleviate any vibration which would lead to squealing? If so, any anti-squeal compound for brakes will work. You just need to use a grease for high heat applications.
1 - 3 of 3 Posts
