1 - 11 of 11 Posts
So my cooling fan has failed. Does the SV actually need a working fan? Would it be safe to say that as long as I'm not in stopped traffic and in hot weather I'll be fine without a fan?
Or, should I get off my lazy ass and fix/replace it?
Well, I wouldn't think that as long as your not in heavy traffic for long or in a really hot climate that it would be an immediate problem. I would just check ebay from time to time for somebody selling one that wasn't asking too high a price for it.
in 135k, the fan on my SV came on exactly 3 times and I can remember exactly where I was each time.
first time was with about 38k, it freaked me out, a new sound coming from my engine
are you sure the fan is bad and not the switch/sensor that that turns it on ?
Yeah, It's usually the switch that goes bad. The motors themselves are pretty tough and like RandyO said doesn't come on that often thus making them actually last for quite some time. I'd check that switch first before jumping on a used fan.
September in Minnesota? Probably no rush to fix it, but you may not want to let it slide too long. Some day next Summer you might get stuck in traffic and forget that you don't have a working fan. That could be bad.
Not sure what the cause is. The manual has some recommendations on how to diagnosis the problem... For the time being, I'm going to enjoy the rest of my warm days and ride then deal with it over the winter.
Most likely I'll be posting a thread needing help. Haha(not joking)
The thermal switch screwed into the radiator is what turns it on. You can test the fan by shorting across the terminals (same as just closing the switch) and see if the fan runs. If it doesn't, you need to make sure that you have 12V+ power to one side of it, and that the fan is grounded.
If this does get the fan to run, then the switch is suspect. New ones are pricey from Suzuki, but an inexpensive alternative can be found here.
It's actually for a BMW car, but it has the same threads and turns the fan on at a slightly lower temperature. (makes no difference, though)
1 - 11 of 11 Posts
