100%I've seen this somewhere else, It's a genius design. I don't understand how anyone is going to learn not to do dumb stuff when there is no chance of getting hurt anymore though.
another step in childproofing the word
It's not about stopping stupidity. It's bigger than that. Bad sh*t can happen no matter how careful you are. Accidents truly do happen. I'm pretty intolerant of dumbasses. That's a well-known fact. But even I don't think people should suffer an injury like the ones that a SawStop saw will prevent.I've seen this somewhere else, It's a genius design. I don't understand how anyone is going to learn not to do dumb stuff when there is no chance of getting hurt anymore though.
We've got several of them out in service and have done dozens of demos with them. The only parts that are ruined are the cartridge and the blade. Everything else survives quite well. The saws are quite well made in general. Easily comparable to a Delta Unisaw or a Powermatic.Have seen this before. I still don't see how the sudden halt of the blade from 5000 RPM doesn't destroy the bearing/arbor/shaft.
I am with DM on this. Watching the slow motion look at what happens to arbor and shaft. Those things are tweaked bad and it can't be good for them. Plus there has to be some deflection (or possible bending) where the the motor mounts to the frame.
Ari...out of all of your demos have you ever checked to straightness, wobble or how much runout there is before and after use?
Don't get me wrong , it is a great safety device and if you are lucky (or unlucky depending on your view) to have to use it then it is worth it.
From the look of it, it deploys with a charge like an air bag ... it's a one-shot deal. Certainly the shoe that jams the mechanism is no good after use.Have seen this before. I still don't see how the sudden halt of the blade from 5000 RPM doesn't destroy the bearing/arbor/shaft.
You obviously did not read my last sentence.What would you rather lose? A finger or a saw?
It comes down to that.
