I've got the everything installed now, finally.
Did you cut or not?
Given that I'm using them on the "S" model, in the rearward position, they have to be at maximum extension or they'll hit or drag on my upper fairing surface. Those of you with the similar configuration, how did you deal with that and how much did you end up eliminating on the riser tube? At maximum extension, they're just way to high and look really dorky. I'm OK with some forward lean, afterall.
I was hoping to be able to make the cut while they are mounted so I don't have to disassemble the bars again though now that I have all new extended cables, that might be easier than before I got the cables. Input on that issue is welcomed, too!
Did you cut or not?
