Hey all, new user here so bear with me as as I try to compile the info.
So I've been in and around the forum trying to fix this problem but I'm going to start a thread to see if someone might be able to help or point me to a resource. Feel free to skip to the TLDR.
I bought my SV650S in November 2021 with 30k miles that apparently was just serviced and had no issues on the test ride, which shortly after getting it home had a pretty badly slipping clutch. It would barely accelerate under throttle, no power, etc. I took the clutch apart and there was no clutch material on the plates, the plates were stuck together, the pressure plate surface was pretty badly scraped, and the springs were worn.
I replaced the clutch pack with an EBC one with springs, and gasket and topped it off with Ecstar Synthetic Oil, and it had worked pretty well for a couple months just fine until the same issue came up. I realized my mistake after looking at the packaging the next day where it said not to use synthetic and replaced the synthetic with R5000 Mineral (which I've been using since), and also did a clutch adjustment following the forum's clutch mantra.
Again it worked OK, but I had a slow drop out of my garage that broke the lever, mirror, shift linkage, and shift lever that I replaced with some ebay aftermarkets for the Levers and mirror and suzuki for the linkage. Regardless after a few months the opposite issue started happening where I wouldn't be able to disengage the clutch and changing gears was difficult to impossible. I readjusted it but nothing. I looked around and eventually found my clutch actuator to be bad and replaced it with a suzuki one with no luck, and also replaced the clutch cable.
I had decided to throw in the towel and give it to a shop nearby, he actually owns a SV650 so I'm pretty confident in him. I get it back in June 2022 with a bill of around 300 for a clutch replacement (suzuki pack), adjustment, etc. As a student that hit pretty hard but I need it to commute to school so I took it home. I've had no issues with the clutch since....until last week. It had been slowly getting harder to shift into gear but I chalked it up to cold weather in the morning, but just last Thursday it would slip like no ones business, rode it home at 25 mph.
I have tried my last resort of replacing the pressure plate, as I did that I checked the plates they were just fine with plenty of material. Topped it off with some oil but I'm gonna try doing a full oil change when I replace the chain (it rusted from the rain) and see if it fixes anything. I also readjusted the clutch again.
With that out the way TLDR; Got my 650S in Nov. 2021 with 30k miles, test drove it no issue, took it home that evening slipping clutch. December I replaced the clutch pack with EBC brand, clutch pack inside had no material and was stuck together and pressure plate was scraped, put synthetic in there, replaced it the next day with R5000 after realizing and adjusted the clutch. Worked fine until it didn't, low speed drop out my garage broke my brake lever, so got some ebay levers. Tried replacing the clutch actuator as it was bad, no luck, tried a new clutch cable, no luck. Gave it to a shop, got it back with the clutch pack replaced with OE and adjusted and it worked from June 2022 until just last week. Tried replacing the pressure plate as a last resort and readjusted the clutch again. Will do full oil change when I replace chain but it's worse than ever now.
Replaced : clutch pack x2 (1 EBC, 1 Suzuki), clutch springs, pressure plate, clutch actuator, clutch cable x2, and levers (ebay chinese).
Issues: Clutch wears out super fast and slips months after replacement, adjusting it to spec free play will not disengage the clutch, adjusting it to where the clutch "works" is 2-3 turns after resistance point on actuator.
I have some other issues with it, but this is something that has broken me, and I'm considering selling it for a VStrom. Any tips? Let me know if I've left something out that might solve the mystery, or if I'm just being stupid and it's staring right in my face. Thanks for reading my post.
