1 - 14 of 14 Posts
Administrator
Domiken
MODIFICATIONS:
2009 GSX-R forks
2009 GSX-R front fender (color matched)
2007 SV1000S OEM full fairing package (color matched)
2007 SV1000S OEM rear hugger (color matched)
PUIG Double Bubble light smoke windscreen
Bikemaster high performance air filter
Bikemaster TruGel Battery
Jardine Dual slip ons
aTre
Power Commander PCIII USB (piggy back fuel controller with map)
Motosliders no cut frame sliders with removable pucks
Motosliders rear swingarm sliders
Woodcraft 3-piece clip ons with an OEM rise
Vortex adjustable rearsets
520 conversion with DID ERV3 X-Ring Chain and new Vortex front/rear sprockets 17/42 gearing
Techspec snake skin tank grips
Vesrah RJL brake pads
Galfer Steel braided front brake & clutch lines
Motionpro revolver throttle kit with adjustable reels
TPS was adjusted and throttle bodies were synced
Secondary Throttle plates removed (STVs)
Pirelli Diablo Rosso Corsa Tires (still a ton of thread left)
Power Commander (PC3 USB) w/Yoshi dual map
OEM green connector fix (common problem fixed)
OEM stator magnet fix (common issue fixed)
1 - 14 of 14 Posts
