Status
Not open for further replies.
Hello,
I have a 2007 SV650, on which I recently installed some Pazzo shorty levers. I installed the pazzos because I was hoping that the adjustability would allow me to 2 finger clutch it. However, I have been running into the following issue:
The bike clutches and shifts as normal when the lever is fully pressed to the grip. However, when I try to 2-finger clutch it (index and middle finger, leaving the ring and pinkie fingers behind the lever) the lever hits my other 2 fingers, making the shifts clunky. It's as if the clutch isn't fully disengaged. If I wanted to adjust my engagement point about an inch away from the grip, would I be able to do that? I have already adjusted the Pazzo to position 6, which is the furthest.
To make this adjustment, can I do it from the handlebar, or do I have to open the case on the tranny?
Thanks.
Banned
Readjust the clutch starting from the actuator down to the lever according to the shop manual.
Status
