Status
Not open for further replies.
hey im new to this site,was hoping someone could help.ive brought a 2001 sv 650s and its seems that the clutch case is weepin oil ive taken it off and put a new gasket on,but yet it still weeps,any ideas?
BannedCampCounselor
Re: clutch csae weaping
First, welcome to SVR.
Second- this is the FAQ Forum and is "The answer forum. To ask questions, go to the WORKSHOP FORUMS."
Check to see if the clutch cover is cracked.
I read somewhere that a supposedly common cause for 1999-2002 SV-650/S clutch covers leaking oil is due to the metal collars pressed into the bolt holes of the cover being a hair too long, preventing the tension of the mounting bolts from pressing the cover against it's gasket sufficiently.
The guy who wrote the piece I read pushed the collars out, ground them down a skosh, pushed them back in, and then reaped the benifits of a non-leaking cover.
Discussion Starter #4
thanku very much for your help,il have another look when i get a chance and hopefully stop the sv from bleeding.
Another common issue with the 99~02's is that the clutch cover gets warped from the repeated heat/cool cycle associated with riding your bike.
You can take some 500 or higher grit sand paper and tape it to a flat surface and then in a cicrle pattern smooth the clutch cover out.
Works for some people...if it's too far out, you'll have to get a new cover.
Status
