1 - 4 of 4 Posts
I snapped the (top) cable adjuster in half at the locking collar a few months ago when riding. So, I got a new one, put it on adjusted it, all is good. Yesterday went out at like 5pm and started it, seemed wierd so i looked under the rubber boot, and its snapped again. What is causing this, I suppose that I had about .25 inches of exposed threads outside of the lock nut, is that to much, should I take more out of the bottom adjuster under the sprocket cover??? Does anyone else have this problem???
I dont want to break one of these every other month, so any help is appreciated!!!
Dave
Discussion Starter · #2 ·
Don't know why that's happening (weird) but it sounds like you've done everything right. It shouldn't snap no matter how much thread is exposed, as there shouldn't be any side load on it. I'm sure you've already done this, but check to make sure that everything is lined up right and that the clutch cable moves freely, and that the adjuster doesn't hit anything as you turn the bars.
When you figure it out, pls. post back.
did you tighten the upper adjustment by hand? if you used a pair of pliers then you may have stressed it when tightened the snapped when used.
SportS
when you turn the bars, the clutch cable is getting snagged and pulling down the housing and breaking off the adjustable collar?
+1. Maybe
1 - 4 of 4 Posts
