so all i have to to is cut a section out of thoes brackets that go over the forks...
and switch sides right on left
left on right....
wounlt that screw with the headlight placement or angle...
· Registered
I think if you switch left/right brackets it moves the headlight down. I also think if you do the switch you don't have to cut anything though.
i would think you have to cut because they would still be the same length sliding over the fork...
the clipons take up space too...
· Registered
My clipons fit behind the bracket fine, it's the turn signal mount near the top they can't clear. It is closer to the fork than the rest of the bracket.
· Registered
Get the lockhart phillips bracket. It looks totally awesome and works well. I just got out to ride mine for the first time since clip-ons and fork oil. You will be very happy.
· Registered
HMMM-- reminds me --I must do something with this set of Tomaselli clip ons.
Fully adjustable ally units. No use for em now Ive got the gixxer front end.
