101 - 112 of 112 Posts
Discussion Starter #105
haha
sorry i have been out of the loop for so long.
and No.. it isnt not sold. but it will be imminently. i am getting it ready to sell right now.
i am getting a new cam chain for it, after replacing the cam chain tensioner didn't resolve the chain clicking issue. I am also re-doing my battery set-up and making carbon fiber lower fairings. It kinda sucks that i am making them now just before i sell the bike.. but it feels like a cheat to have those crappy alloy plates there on the bottom.
Got it all torn down to replace the cam chain tensioner
My new battery set-up. Three 4-volt 8-amp batteries wired in series in order to fit in the tail.
And.. as promised a long time ago i am going to show some more CF work as i make the lower fairings. For ease of fabrication i am going to make a positive blank out of foam then make a fiberglas mold from that that i will then make the final part out of.
So... here we go. i have the foam cut roughly to shape and the preliminary bevels cut on the bandsaw.
then i clean them up and put the bevels more where i want them. i am using a long block with 50 grit ceramic sandpaper. I try and finish each step on each peice to keep them as much the same as possible, rather than finishing one and going to the next.
keep the flat lower bevel and radius the top one..
Now i have chiseled and sanded a detail onto one and am transferring it over to the other. this stuff works alot like soft wood without the grain problem. it is alot of fun to work with.
and a little bit more tweaking with a lateral detail
now i have both sides to the same stage. i still have to go in and do the final tweaking.
i am at a little bit of a creative loss. i think it needs a bit more detail, but i am not sure what to do with it. any ideas?
thanks
~Chris
Discussion Starter #106
Okay... got some more work done.
got the molds sealed with resin.
then sanded them down, primed them, sanded and buffed them before waxing and releasing them.
then i made the molds..
let them cure overnight, and popped them off. now i have to touch them up before priming and preping them for making the real parts. the benifit to these parts is that i can lay up the part in the mold and then press the mold onto the plug to remove as much gap as possible.
And
i forgot my camera at work yesterday so i dont have any pictures of the lay-up but it is very stright forward. resin on the mold, layer of fiber, little resin.. layer of fiber, little more resin...
Here is the cured part sandwiched in between the mold and the plug;
and after i popped the plug out:
and i had one of the part after i got it out of the mold but i didnt realize till i uploaded it out horribly blurry it was.. so you will just have to imagine in. sorry...=(
and here are the two parts after sanding them down for the final coat of resin. i had a couple bubbles get trapped, so the final resin coat will make those go away, then i will sand it down, cut the "scoop" and then paint it.
I havent decided how i am going to do the white stripe on it... so any of you artsy guys wanna give some input it would be appreciated
thanks!
~Chris
Discussion Starter #107
well i got the lowers wet sanded and then masked them up for the white stripe
then painted them...
now i am ready to do the clear coat on the fender, fly-screen, and lowers
also... bad news. my engine developed a knock... so i took off the oil-pan and found this:
long story short, the motor will take more money to fix than it will to get a new engine... so i did that
low mileage motor in better condition than mine ever was, and it came out of a running bike.
the donor heart waiting to get grafted in.
My question is this: the gold on the covers will stay the same, but i cant decide if i should do the new motor in the same cast iron gray or if i should just black the motor out
thoughts?
Discussion Starter #108
I got the engine clean.
after i wore my fingers to the bone getting all the crevases in the engine with scotch bright and engine degreaser a bussy told me about easy off. i could have saved my fingers. it etches the aluminum some, but tha tis okay for me as i am going to paint it anyway, but it didnt eat the painted covers...
All foamy
Now it is all clean. i have all the holed blocked off and after i took the picture i finished masking the wires and plugs.
any idea how i can hold this sucker so i can paint it all at once?
Discussion Starter #109
thought i would show a little honda pride... i think it makes the tank look a bit more "finished" the red pinstripe still has to go on.
and i got the engine painted for real. I am letting it dry all day and tomorrow morning. hoping to pull the old engine out tonight, and put the new one in tomorrow. the bike will also be getting a top to bottom cleaning while i have it all apart.
i love how the bike is lurking in the background...
Discussion Starter #110
Got the newly painted new engine in..
Changed the oil, new coolant new sensors, and slapped the carbs on there.
got everything mechanical together and hooked up. i swapped out the cam-chain tensioner, so when i starts up i hadn't adjusted it yet, and this is a cursory adjustment as it will get tweaked further when the bike has a chance to warm up.
this is the first time i tried to fire the bike up. and it is running on starting fluid and about 2 oz. of gas i put in the fuel line hence it wanting to die at the end of the video.
Discussion Starter #111
Here it is put mostly back together. I had it all back together but there was something clogging my #2 cylinder slow jet so i took the carbs out and cleaned them really well.
Also.. i am a real pro at disassembling this thing now. i can take it from fully assembled to body off, and carbs out in 8.7 minutes.
I also finished painting the new parts... (and repainted a few old ones)
mechanical work was finished on saturday and then it took my a couple hours on sunday to make new brackets for, and mount the new lowers.
then i took them off and buffed the paint and put the stripe on them, but i didnt want to pull it back out in the dark. more pictures of it soon. my dog was checking it out.. but found the trash on the floor more interesting. We had a talk about that.
thanks for looking! more soon.
~Chris
