1 - 2 of 2 Posts
Releasing clutch and getting into 1st gear from stop is choppy/ jumpy and throttle unpredictable. Sometimes it even dies before getting into gear. It's all great after 1st gear.
Sometimes it feels like it's running on only 1 cylinder on 1st, then the other cylinder comes on. Brappp...brapppppppppppp.... brappp...brapppppp. on and off like this. Annoying
Getting into 1st gear seems fine though when I increase the idle-dial to 2,000 rpm parked.
From what I think the cause may be:
Fuel (93 octane)
Chain slack
Air filter
Dirty carbs
carb sync
fuel lines
Going to get these checked out.
Any other ideas?
If it's defiantly a engine miss fire my thoughts are on the fuel sideof things, one carb flooding a little from a dirty needle valve or on the spark side high tension spark plug leads.
But I must say my o2 sv650 has seemed a bit hard to tame off the mark, but, I just changed to a clutch lever with a different ratio giving a lighter feel and slower take up with good success.
1 - 2 of 2 Posts
