I know there is a TPS on the 1st gen.. it probably has something to do with the fuel pump on the SV rather than gravity/suction fed systems... so the bike would need to know when to feed fuel to the carbs... I dunno... it is just a guess... here is a little info I could find on it... some may know all about it, but there isn't a lot of info... I'm not sure if it makes the same impact as on the 2nd gen... so that is probably why...
I just found it... check the 1st gen Suzuki service manual everyone has from the torrent.... Chapter 4 page 33 under "Fuel and Lubrication System" It tells you how to position it too.... check 4-33 (I think it is page 200 in the PDF file from the link below) It is adjusted with a volt/oms meter and measuring resistance... or something like that...
If you don't have the manual here is a link to an online PDF (warning it is large and takes a long time to download and display as it is about 73MB and slow to d/l) you can find it at a number of places, however this one is at the following address.. or you can d/l it in the torrents...
http://www.carlsalter.com/aaman/Suzu...99-'01.pdf
You can also look at this link.... it talks about de-restricting carbs on the Brit/European 1st gen bikes and they show a section detaching the TPS
The bike has an electronic fuel pump not gravity/suction fed so it makes sense for the bike to know when to feed more gas to the carbs..
Anyway here's the link..
http://forums.sv650.org/showthread.php?t=62081
This link also mentions the TPS http://www.suzukicycles.org/SV-serie...0-SV650S.shtml
You can also check the Clymer manual for Suzuki SV650, 1999-2002
under the following:
CHAPTER EIGHT / FUEL, EMISSION CONTROL AND EXHAUST SYSTEMS
Carburetor operation / Carburetor / Pilot screw / Fuel level / Carburetor float height / Throttle position sensor / Carburetor heater (U.K. models) / Throttle cable replacement / Starter cable replacement / Air box / Fuel tank / Fuel valve / Fuel pump / PAIR (air supply) system / Crankcase breather system / Evaporative emission control system (California models only) / Exhaust system
I believe it is just on the rear carb and the part is 13580-19F00
I think that is the part anyway.... if you check RonAyers.com
