This took 20 minutes (on my '01 naked SV) start to finish including putting tools away and covering bike back up. Refer to manual!
REAR PLUG:
-Remove tank rod from under rear seat or cowl.
-Remove tank bolts and prop up tank with rod.
-Remove spark plug cap and plug using stock plug wrench and 14mm open end.
-Replace plug with new (gap set) plug. turn approx 1/2 turn past seated to collaspe new crush waser.
-Replace plug cap (arrow to exhaust), lower tank, replace bolts, replace rod, replace seat/cowl.
FRONT PLUG:
-Remove horn using upper bracket bolt to frame ONLY
-Remove right side radiator bolt that secures radiator to front head.
-Use a 2X4 Flat-short side to prop between the radiator and the head bracket. This should fit between the head bracket and BOTH boths on the radiator that hold the electric fan (no denting the rad. fins)
-Remove cap, remove plug using stock wrench and 14mm open end.
-Replace plug (w/proper gap) and tighten 1/2 turn past seated
-Replace cap with arrow pointing toward exhaust.
-Remove 2X4 and replace radiator/head bracket bolt
-Replace horn using the one bolt you removed.
-DONE!
Once again, twenty minutes start to finish including clean-up.
REAR PLUG:
FRONT PLUG:
-DONE!
