Just wondering what the difference in the number of links between the two bikes is?
are 2nd gens different than 1st with regard to chainlengthwacky_woodchuck said:112 Links for the Naked (SV)
110 Links for the Faired (SV-S)
Reason.... Naked has a 45T rear sprocket and the SV-S has a 44T rear sprocket. The engineers at Suzuki figured the one tooth less would warrant another part number. :![]()
Maybe I'm wrong, but I was refering to all. I know when I went to order a chain for mine, it was 112 links and that's what I order. I have no problem with it.RandyO said:are 2nd gens different than 1st with regard to chainlength
1st gen nekid 110 links, S 108 links
Right.. and when I measured them up to cut off the excess (oem next to the new DID), it was 112, not 110.RandyO said:112? most chains come as 120 link and you cut the excess links off
did you actually count links or was your 110 link chain stretched to the same size as 112 unstretched links?wacky_woodchuck said:Right.. and when I measured them up to cut off the excess (oem next to the new DID), it was 112, not 110.
Counted.RandyO said:did you actually count links or was your 110 link chain stretched to the same size as 112 unstretched links?
Proven wrong... gee this is like home... ;Dandy4us said:You miscounted WackyFirst gen S is 108 and naked 110.
http://forum.svrider.com/index.php?topic=19134.0
Andy
