1 - 20 of 23 Posts
http://www.wired.com/autopia/2012/07/roskva-cf-bike/
Instead of a steel or aluminum frame, Roskva uses a carbon-fiber monocoque weighing about 55 pounds, along with carbon fiber wheels, single-sided swingarm, and an enclosed driveshaft. The battery inside is made of 414 individual lithium iron phosphate cells with a 6 kWh capacity. The batteries power two Lynch D135RAGS electric motors that deliver 59 pound-feet of torque and 96.6 horsepower. They hope to achieve a drag coefficient “lower than 0.30″ by incorporating a chunky tail section that, unlike the aesthetically driven design of modern bikes, will reduce turbulence.
http://roskva-electric.com/
I applaude their ingenuity, and I wish electric bikes the best, but you won't be seeing me on one... I'm sorry but to me riding a bike that makes no noise, is like having sex with a woman who doesn't moan... How sad is that?
-"Oh, you like it don't you?"
- "Bzzzzzzzz" -_-
- "Bzzzzzzzz" -_-
HAHAHA Agreed... but a little weirded out...
While it does have 96hp, it's direct drive so the top speed is only 110 or so, and it's 0-60 is speculated to be in the high 3s.
I also wonder if the range is based on typical 'commute' driving styles, or aggressive track riding? Sure would suck to take it to a track and find out the batteries are dead after 30 miles.
Everytime I hear something structural was made out of carbon fiber I think of the tent rods that snapped in my hand when I was 12 and left me with a million fiber glass splinters..
I know they aren't the same thing but it's just similar enough- if you dropped this bike would it not shatter and crack into a thousand pieces...
Not really but damage to this bodywork is basically damaging the frame and since the bike was not made using a mass fabricated mold which means it would be extremely expensive to repair or replace.
In other words don't drop it.
Not necessarily, F1 suspension components are made of carbon fiber but when they hit the wall at 180+mph they don't shatter like your experience with tent rods. Its all about the resins and coatings they use.
The good news is it is not likely to dent, the bad news is it will likely crack in the event of a run in with the ground, and that is not an easy thing to repair.
Still a cool concept.
Discussion Starter · #20 ·
1 - 20 of 23 Posts
