I've barely owned this for a year, it has 33,000 miles on it so without knowing it's maintenance history over the winter I decided to remove the carbs, clean and check the float bowls R&R the float needle and seat, which I'm glad I did due to fairly clogged screens on them and put a new bowl gasket on them. Now for some reason I'm getting a vacuum leak from the float bowl vent!! I have rebuilt many different carbs in my life and never heard or seen this before! The simple half cleaning and inspection I did should not have caused this, they were running o.k before. What am I not seeing or figured out about this? I do not see anything wrong with the manifolds, And getting the carbs to fit is a bite for sure! After removing then for a 3rd time I went through with carb cleaner checking the various ports I thought I might have gotten dirty, all seems good. I would appreciate any input! Thanks!
