1 - 10 of 10 Posts
I've got a 2005 sv and i have noticed a couple of times i havent been able to get into 1st gear. it mainly happens when im stopping. a couple of times i have not been able to get it ot first and have to start in second. Ive tried to roll foward a little and it dosent help i have let off the clutch a little and that worked. i was just wondering if i was doing something wrong or if my bike is messed up.
Is it when you are stopped? From neutral they commonly won't go in, just let the clutch out and pull it again, will be fine.
+1 on the letting the clutch out a little.
Bike gearboxes can be a little reluctant to shift when there's no load on the box.
Rocking the bike back and forth should work as well,
but letting the clutch out a little to put load on the box is prob the easiest way
normal :-*
This is a common problem with all motorcycle transmissions. Just keep pressure on the pedal and ease the clutch out. It will pop right into gear. If you aren't taking off just pull the clutch back in. If you are taking off you will just take off normally.
You may want to check your clutch adjustment, both freeplay and the lever under the front sprocket cover.
This happened to me for a while too and I also had a rough time shifting to neutral at stops. I adjusted my clutch cable then all shifting up, down, neutral were all smooth and effortless.
Happens to me too. You'll probably see this decrease in frequency as you break in the gearbox. As said before, ease out the clutch a bit and try shifting again, it will go into gear.
happens to me all the time... just let the clutch out a bit and then put it back in... after a while, you get used to it and you'll do it without even realizing (kinda like the habbit I formed of making sure it's in 6th before letting the clutch out due to the occasional false neutral :D )
ohhhhh man that sucks! I had that happen to me and it was the start of needing a new tranny!! can you say $$$$$$$$$$
..... ;D
Nah it's normal... don't worry about it too much.
1 - 10 of 10 Posts
