I'm sure this has been asked and answered, but I've searched and can't find the answer! Has anyone put a 45 tooth rear on an SVs (has a 44 tooth rear) and been able to utilize the standard chain with OK results?
no such think as an odd number of links in a chain cause of the way they'rer constructedPREZ said:Usually, for every tooth you go up (c/s or rear), it requires 2 more links of chain. It varies depending on chain mfg. as well. If your chain has already stretched then you'd need no extra links, but you should always change chain and sprockets as a set to get optimum life out of them.
If you check the specs section in the back of your owners manual, you'll see the naked has 110 link chain and the s has 108 links.
Edit: Posted in your other thread.
Just replaced my chain (stock SVS sprocket sizes), I got the EK 110 link from Oneida for $61.99. With 110 links I had no adjustment left and excessive chain slack, so I got out the chain multi-tool and removed 2 links. Not good, it was way too short. You should be fine with 109 links for either.
Well then, I must assume that the mfg. made a big goof and sent me an odd number chain. :-\RandyO said:no such think as an odd number of links in a chain cause of the way they'rer constructed
COUNT YOUR LINKS , total # of links must be even or it will not connect, no such thing as an odd # of links in a chainPREZ said:BTW, I put one of the 2 links back in and it was right, which is how I arrived at the odd number.
It will be fine. I run 15/45 on an SVS with 108 chain. I think a 46 will even fit fine.cyclerider105 said:I'm sure this has been asked and answered, but I've searched and can't find the answer! Has anyone put a 45 tooth rear on an SVs (has a 44 tooth rear) and been able to utilize the standard chain with OK results?
Sorry Randy, but I have many other things I'd rather do than count chain links. As I said, the mfg said it was 110............... I just know what I did.RandyO said:COUNT YOUR LINKS , total # of links must be even or it will not connect, no such thing as an odd # of links in a chain
