1 - 4 of 4 Posts
kinda hard to tell in the pic... is there a screw(s) you can remove to pull the "stub" out of the clip-on clamp and put the bars directly into it without the riser?
I know the gen1 risers are 1 piece and you'd have to cut them to use the risers, I suspect it's the same with your bike. So you'll probably need to replace the clip-ons... luckily they're fairly cheap.
andy4us said:
Undo the pinch bolt and slide the clamps down the forks. You will loose the bolt that attaches to the triple clamp, but it's useless anyway, so no big deal.
Andy
That's what I was thinking. Will that cause any problems with suspension travel or anything like that?
1 - 4 of 4 Posts
