I installed GSXR calipers on the stock forks using the adapter brackets and now it looks like both the calipers are not centered over their rotors. There is about 2x more distance to one pad than to the other. Is this normal??
Also, while installing the new pads I put that anti-squeak gunk on the back of the pads. But to fit the new pads over the rotor, I had to push the pistons all the way in, so the gunk probably got all over the inner surfaces of the calipers as well as the piston seals. Bad?
Maybe I'm just being paranoid with this stuff, but I realllly don't want to mess up my brakes. That might end badly...
