1 - 4 of 4 Posts
I Think I am going to order a set of side by side headlight from busters in the UK. I heard that they are plug and play but do they use the same mounting bracket as the factory or do they come with one? If they come with one does the new one alow for clip ons to be mounted and where do the signal lights go?
thanks Bill
Yes you can get them to accept the stock mounting brackets. Or you can order different brackets its up to you. (if you are going to run the stock turn signals id stay with the stock mounting brackets).
If I order other mounting brackets will they alow for clip-ons??? And do I order the brakets from busters???
Bill
Yes if you order there brackets you can use clipons. You can also get them from lockhart Phillips but i think they are more expensive.
1 - 4 of 4 Posts
