The subject says it all. I have a pair of these signals with no nuts - does anyone know what the size is? I'm going to get these at Home Depot or Canadian Tire or something. Thanks for any help.
-A
-A
To mount the front blinkers, I made a bracket out of a 3mm abs sheet. I installed it inside the fairing and then I attached the blinker on it.\"HKer\" said:You doing it on a naked, or S? I've only done the rears on my S, and still need to do the fronts. It looks like the mounting on the fronts is different, so I don't know how I'm going to do that just yet...
EDITED to add that you will also need bullet type connectors since the Buell is not the same as the SV.
