I am in the process of changing my SVS to a Naked. I picked up a Buell headlight (not the two light streetfighter set) and have mounted it up no problem. The only issue I now have is that the headlight seems to blow fuses on the high beam setting. Also, when you switch to high beam, the light seems to take a while (about 2 or 3 seconds) to go from a dim orange to bright light. Seems like a low current problem.
I know that lots of you have made a similar mod without problems. Did you add something to the wiring setup? I just wired it up to the original headlight wires - although there were three wires on the headlight - including what I think was a low level parking light.
Any ideas?
Thanks.
Any ideas?
Thanks.
