#30 on this fishe. Part #25600-33E00
I had the same thing happen to me and just drilled out the shifter lever and replaced it with a bolt and nut using the stock rubber. Many people have done the same thing. There is also a replacement lever you can get off Ebay that folds. Somebody will most likely throw you the link in a little bit.
http://fiche.ronayers.com/Index.cfm...del/SV650S/GroupID/263927/Group/GEAR_SHIFTING
