Hello fellow SVRider family! It has been several years since I have owned an SV650, and somewhat recently I was told about a motorcycle that was sitting on the side of an acquaintance house. To make a long story short, he needed assistance moving it.... as a joke I stated "Provide me the pink slip and I will move it quick!". Turns out my friend was open to the idea and he handed it over. So the story of myself and this bike begins....
What I know:
- Motorcycle was in a minor drop/crash.
- Was sitting for about 1-2 years.
- Gas tank was left open :eek:
- Prior owner did not know how to do maintenance on motorcycle
- I got a lot of work to do.....
NOTE: See how gas tank was cracked open...
Time to give a BATH!!!
More to come....
Discussion Starter #2
So there is a lot of work to do here.... but closer shots of what is to come.
A quick list of things I am going to get to get this project going.
- Fluids (Oil, Coolant, Brake)
- Oil Filter
- Air Filter
- Spark Plugs
- Chain
- Grips
- Bar Ends
- Rear Sets
- Brake Pads
- Brake Rebuild Kits
- Rear Sprocket
- Will make much bigger list as we get moving.....
All I need now is a BEER :eek:ccasion14: !
Discussion Starter #3
Purchased a couple things and getting ready to get to work. Majority of parts purchased NEW. Found a used K&N filter online so, will clean and get her on.
Lets just look at this picture to remember where we started.... What I can tell you is at least the dude lubed it, because there was about 4 inches of wax lube built up in the primary.
Here are some of the goodies... no need to explain.
USED K&N Filter.... Will clean and put her back in!
This is how I always like to do work.... NAKED!!! :rock::lmao:
Discussion Starter #4
So here is something I can do quick! Lets take care of that seat that looks like someone with spikes on their A$$ went on a ride.
Things you need:
Staple Gun
Marine Vinyl
Foam
A friend to talk smack
1 or 7 beers :eek:ccasion14:
BEFORE!!!
AFTER.... Makes me want to sit on it now. Ok, back to important stuff like getting it running.
Discussion Starter #5
This may be a slow build due to a thing called family and adulthood. Either way time to make a quick change of the damaged rearset.
BEFORE:
AFTER All I did was found some inexpensive chinese brand that was on eBay. It does the job and look and function is much better.
Apologize for slow progress, but I will continue to update as time allows.
NEXT UP - Rebuild Breaks
