Hi. I have a set of brembo brake from a 2011 gsxr750 K11/L1.
It's going on to a 1 gen sv650.
I'm using 97 srad wheels & rotors
I have a set of 06 gsxr600 forks (Gold)
The caliper hole look align just offset a bit.
Please see pictures.
I think i need rotor spacer.
Where can i buy some or i just use individual washer on each hole?
Pic 1&2 could see the offset.
These are the forks i'm putting on.
SRAD wheels and rotors won't work with those forks, you need 06 and up wheel and rotors. As far as the brake caliper I have no idea. Those are very new but i'm sure there will be someone on here that can help you with that.
By the look of it.. I think if i slap the brembo on the 06 forks all i need is rotor spacer... got any sources?
Mak.
Best thing you can probably do is find a machine shop that can make those for you. The actual process of making the spacer themselves is straight forward but making sure the measurements is the key.
Zoran sells caliper spacers, for diameter. He seems to need rotor spacers, for width.
