I've done some investigating so far, but here's the gist:
I noticed one night my brake light wasn't coming on. Tail light works, I just noticed it didn't get brighter. Both front and rear are not lighting it up. So today I checked the connections and used a multimeter to do some test. The switches themselves have continuity. But there's no power running through the wires to the front switch (nor was there any power at the last connection to the tail light, which is redundant to say, but just noting). The fuse is good and I confirmed that power is running through the fuse box. So I checked the wiring diagram and it looks like there's multiple points I need to check. Only problem is, I saw where one of the wiring connectors is... behind the frame and in front of a cylinder, where it's going to be one hell of a time trying to get it out.
My main question here is does anyone know of any common points where connection is lost/corroded/etc.? So at least this struggle can be minimal.
The only thing I've done to the bike recently was a new rear tire. Other than that, it has been in hard rain more than usual. Even though it was under a cover, it was still wind driven into it more days than not.
