Can to much oil keep my bike from starting? How long does gasoline keep in the tank if the bike is in the garage for a couple of months without starting it?
CorrectToo much oil is not a good thing, but it probably won't prevent starting. Gas can be pretty volatile, is the bike cranking but not firing?
No. Yes.06 is a Gen2, just so you know. Is this bike relatively new to you? When you turn the key on, do you hear the whirring of the fuel pump prime?
Do not jump 12v to the fuel pump as mentioned below. Instead, turn the key on/off three times. Each on/off will run the fuel pump for 3 seconds for a total of 9 seconds, easy and close enough.TeeRiver,
What's a fuel volume test and how do you do it?
