Had a little bingle and put a bit of a bend in my forks on the upper section just below the crossbar spreader. I was wondering if I'll need to replace the whole fork assembly or the bottom outer section might be ok.
(2003 SV650)
Thanks.
Discussion Starter #3
I've been searching ebay and found heaps of the top tubes but almost nothing of the bottoms or complete unit.
Hmm, that sounds odd. Most of the time in a crash the upper tubes are bent but the lower (slider) tubes are fine. So eBay usually has the reverse, lots of good lowers but not many uppers.
I can help you if you decide to do the gsxr swap. I have 05 600 forks/trees with ohlins internals that I will not be using anymore. PM if interested and I'll service them prior to shipping.
Sent from my SM-G973U using Tapatalk
