1 - 20 of 686 Posts
Don't belts loose some of the snappiness of the bike?
That's kinda cool but but...ehh... it just doesn't seem right.
it looks kinda narrow, even with 70-75hp i'd be afraid to trust it. looks smaller(i could be wrong) than a hd 883 sportys and those are mid 40's hp
That's just wrong! :-\
Somebody's got the idea:
Can I get 200lb of chrome and an oil leak to go with that?
;D
For certain uses (i.e. touring, commuting) it might be the real deal. I wonder how much they're asking for it?
Keep running that belt on the dirt and you'll see why dirt bikes use chains. ;)
Get a rock or even a stick caught between the belt and the driven wheel.. BAM!.. Split belt...
Torque is the more imporant factor to consider here.
yeah, you're right, don't know why I didn't think of that. But, then again you don't see any il4 600's that only have peak torque that is compareable to our sv's using belts.
don't Buell's run belts? think I remember reading an article on the new Buell and think the rider doing the evalutation claimed he liked the belt drive claiming it was snappy in response
I don't know... I have never ridden a bike with a belt but the idea is appealing if it means less messing with compated to chains and longer life. I don't like having to remove swingarm though when its time to replace
Buells run belts - but the drive on this SV is WIDE open for stuff to get jammed in there.
A Buell has covers galore - a key ingredient in longevity.
Not hard to execute - but some covers need to be added to make that truly reliable.
ohh I see... is an interesting idea if you could keep it covered I guess ;)
finally, a solution for my lazy non chain cleaning/maintaing ass.
belts are lighter than chains and therefore less driveline power losses
Not sure if this one one of them, but they make belt that can handle rocks and debris now. The Buell Ulysses has one. In testing the just sat there and fed metal rods into the belt to try to make it fail. It did so well the owners manual no longer calls for a belt replacement at 20k. It's now lifetime.
doubt it, this is a custom made job by a guy on the SoCal SV board.
1 - 20 of 686 Posts
