1 - 10 of 10 Posts
Anyone know of a manufacturer that makes a thigh grips for below the tank? OK, I'm 5'5". my thighs ride perfect on the plastic piece right underneath. Maybe I just need some some material to cut some out. Ideas?
I'm in the same boat. Nobody makes anything I've seen, maybe wrap in skateboard tape.
The other further out idea I had was to laser stipple them but I need to find a extra set to try it on first.
You can try Stompgrips. I got them for mine and it came with 4 pieces, 2 for the tank, 2 for below.
Stompgrip Tank Kit Volcano Clear 55-10-0136 https://www.amazon.com/dp/B06XJ1KH21/ref=cm_sw_r_cp_apa_i_s4RODbQ4710DP
Alternatively, you could try rearsets that could get your legs in a higher position. Ideally you'd like to get your legs on the tank but if you control the bike fine as it is then I wouldn't go that route.
Discussion Starter #5
I'm trying to get in touch with BigHammer but no response yet.
Thanks for the suggestions!
Discussion Starter #7
I did get a hold of Pete (bighammer). Looks like he's going to supply a pair.
Thanks!!
Post a follow up, curious to see.
I got full tank grips now but only use the bottom half at best haha.
Discussion Starter #10
@Labora An old picture, but you get the idea, Stompgrip tank pad lowers
Yep, those ones below are what I'm looking to get. I want them a bit bigger though so if fills entirely that front portion of the panel.
1 - 10 of 10 Posts
