1 - 20 of 27 Posts
buy a complete lower and mount it
yep. but if your going to be racing your going to want full fairings. The wind will take a toll on you. Clip ons are better in every way over standard handlebars. It doesnt take much work. I mounted a set of 04 GSXR 600 fairings with a matching stay and only had to make a couple simple brackets. Probably woujld take less time than trying to mount just a belly pan.
do you guys know of a ccs legal belly pan for a naked?
I still use the stock N handlebars and don't really want to convert to clip ons and bodywork.
You will kick yourself the first time you lay the bike down in any way and break the clip ons, and no one will have a stock spare (because they all converted to aftermarket clip ons).
still have the molds for the belly and the upper...for sale, make as many as you want.
edit: just realized this statement may be confusing, I am not making these parts anymore, however I still have the molds and they are for sale.
Champer is absolutely correct, if your racing your bike is bound to hit the deck. Get some clipons and bodywork. The bodywork will help keep parts a bit safer and keep the wind off you. You will be surprised at how better you can rider when having wind protection. Wind buffetting and the noise alone being taken away will help your concentration and you will be able to hear alot better as well.
PM sent.
Your brake lines would be a bit long if you converted to clipons but it would still work. I went from naked with bars to naked with clipons and I eventually swapped out the brake cables, throttle lines and even the throttle housing to the S version for a better fit and finish but it would still work, especially since you are not running stock plastic up front, you have a lot more room so your cables won't be getting hung up.
Discussion Starter · #16 ·
which fairing stay would I need? Ive heard race bodywork is meant for one of the gsxr years but then I also see the woodcraft ones.
and also does the bodywork come with all mounting hardware and instructions where to mount it?
If you are buying new bodywork there is a company called motofairings.com that has some bodywork for like $280 I think and it comes already drilled, so you don't have to worry about lining it up and putting it together. A friend and SVrider has a set and it looks good. You can get either woodcraft or vortex fairing bracket and you will need to buy Dzuz fasteners to button everything up.
1 - 20 of 27 Posts
